Welcome to Club SAITO !
Old 12-19-2019, 07:47 PM
  #44351
the Wasp
Originally Posted by FlyerInOKC
Speaking of gifts thanks to Jim I now have a Saito .82 in possession and she is a beauty! For Christmas my oldest son bought me a spinner from Sarik Hobbies in the UK to fit a 69" Brian Taylor Spitfire 1a. Looking at the plans the Spit calls for a .70 to .80 4 cycle (Class act he didn't even mention a 2 cycle engine.) so that gave me ideas. The spinner has been around a while the label taped to it still says Traplet on it and it definitely will need polishing. The spinner set came with a 97 mm diameter back plate, 75 mm tall cone, a 14" hex nut (Measuring 1 3/8" long or 35 mm if you prefer), and a 50 mm countersunk screw in need of having the threads chased. Now that I have bored you to tears, has anyone here put a scale spinner on a Saito .82 before? I was thinking maybe a ready made adapter like a TruTurn might work, any suggestions guys?
aah shucks nothing to it , and your welcome, I was just passing along the friendship,
about that spinner needing a polish, you could polish it on the engine if you could get it started withOUT a prop on
Jim
a tidbit of life: don't spend all that money setting up to go fishing, just buy the minnows and put them in the fish tank, then a few months later you'll have a feast
  #44352
Hyjinx
Originally Posted by 1200SportsterRider
I had to re-register after the changes, am now the User Name you see, with the CHI unit you can creep past the sensor and it will spark. You're right, the RinkyDinXL unit has not made me a fan yet. Remember that retarding the timing makes engines run hotter than advanced. Later timing means that the combustion process is exposed to more naked cylinder wall.
Ta Da
Just as weird as it was when it logged me off and would not let me reset a password to log back on.
It just logged me on and let me post without succesfully resetting the password.
Hello all
Guess the small g gods will abide my lurking and off kilter Saito banter occasionally.
Heard from the jokester from down under?
Wonder if he's been computer neutered too....
Old 12-19-2019, 08:03 PM
  #44353
the Wasp
Originally Posted by Hyjinx
Ta Da
Hello all
Pete,, we'er miss you our Saito friend
Jim
Old 12-19-2019, 08:45 PM
  #44354
FlyerInOKC
FlyerInOKC's Avatar
I'm glad to see you're back Pete!
Old 12-20-2019, 05:06 AM
  #44355
1200SportsterRider
1200SportsterRider's Avatar
OK, I ordered an APC 12 x 5 to run on the Saito 60 twin, I broke my own rule to do that.
Not many of the Remote Glow adapters will fit the OS-f, the Sonic-Tronics will and the Sullivan will with a little jiggling.
Old 12-20-2019, 05:35 AM
  #44356
Glowgeek
The Sullivan fits an OS F plug very snug, yes. I like them. I've not tried the Sonic Tronics version.
Looks like Sonic Tronics offers a standard 5/8" adapter and a 1" adapter for deep recessed glow plugs. They offer the complete remote kits and also offer the plug adapters separately. Very cool!
Tip: The little angle bracket is flimsy on the Sullivan and can bend over time, especially if I press too hard while inserting the glow ignitor. I sand the inside radius of the bracket a build up a solder fillet on that inside radius just at the two outside edges. That trick almost doubles the strength of the bracket.
Old 12-20-2019, 05:58 AM
  #44357
acdii
Just what I was looking for. Sonic Tronics Inc /...
Old 12-20-2019, 06:14 AM
  #44358
Glowgeek
For your YS with the deeply recessed glow plug the 5/8" long one in your link may be difficult to install and remove. The 1" long one may work better.
Old 12-20-2019, 06:40 AM
  #44359
FlyerInOKC
FlyerInOKC's Avatar
OK am I being suspicious or does the Sullivan look like the Sonic Tronics the only difference Sullivan assembles it for you and charges accordingly?
Old 12-20-2019, 07:00 AM
  #44360
Glowgeek
It would appear so. I am going to use the Sonic Tronics on my next build. The 5/8" kits appear to be virtually identical with the Sullivan just costing more, perhaps just branding cost.
Old 12-20-2019, 11:14 AM
  #44361
Jesse Open
Jesse Open's Avatar
I use the short ones on everything. Simply solder a brass strip on the side and bend the end to form a tab.
Old 12-20-2019, 11:44 AM
  #44362
Glowgeek
Well, isn't that a fine idea.......for those who aren't soldering impaired. Might even weigh less than a longer glow plug adapter.
Old 12-20-2019, 02:47 PM
  #44363
Glowgeek
Gary, returned PM
Old 12-20-2019, 07:04 PM
  #44364
Jesse Open
Jesse Open's Avatar
Gary, returned PM
Replied
Old 12-21-2019, 03:27 AM
  #44365
Glowgeek
Replied
Old 12-21-2019, 04:14 AM
  #44366
1200SportsterRider
Originally Posted by BarracudaHockey
I'm sure we will get it straight.
Andy, Peter Yearbury/AKA Rudolph Hart is also locked out same as me, Thanks There could be others because there is no way let anyone know, Pete had an E-Mail from me a few days ago and used that.
Old 12-21-2019, 07:48 AM
  #44367
Captcrunch44
Wow I am still here
Old 12-21-2019, 10:53 AM
  #44368
1200SportsterRider
Originally Posted by Captcrunch44
Wow I am still here
It was not a good time to forget your password.
Cap or Lonnie, you been thinking about any 50 stuff you might need.
Old 12-21-2019, 10:56 AM
  #44369
1200SportsterRider
You guys are a riot!
Castor makes a great assembly lube for our little toy engines, why use anything else?
3 hour Epoxy would be just as good.
Old 12-21-2019, 11:47 AM
  #44370
Glowgeek
Hahaaa, good one Dave!
50 stuff, hmmmm. Not for a 50 but parts to finish converting a 45 MKII to an S. I'll check this evening and see what all I'm short.
Old 12-21-2019, 11:59 AM
  #44371
rafeeki
rafeeki's Avatar
Gentlemen
Im a long time follower of this thread with several Saito Fa 180s and one Fa150 flying 1/4 scale Tiger Moth, Pitts and Soitfire soon will be flying a retired Giles 202 also.
At this point I need a NIB Saito FA 82 to match the other one I just purchased on line to bring back my Top Flire B-25 to life.
Anyone has one??
Rafeek
Old 12-21-2019, 01:07 PM
  #44372
Captcrunch44
yeah I need all you got I have a 56 I would like to put back together
Old 12-21-2019, 01:08 PM
  #44373
Captcrunch44
Originally Posted by rafeeki
Gentlemen
Anyone has one??
Rafeek
i have one that is almost new in the box
Old 12-21-2019, 01:40 PM
  #44374
1200SportsterRider
Post number 10
Old 12-21-2019, 01:43 PM
  #44375
1200SportsterRider
My Saito work yesterday did not involve a Saito, just to hope for one.
I did that all by myself.
